Low speed whine
Hi all,
I have an 08 528xi, 1195xx miles. At lower speeds, mostly when pulling away from lights, I am getting a whine from under the hood/transmission. It only happens under throttle load and seems to be most prominent around 2000-2500 rpm.
I have a fear that it is the torque converter, but I am hoping its something a little easier, maybe a power steering pump? Does anyone have any tips how to either diagnose the true problem or have any experience with something similar? If so, please let me know what your problem was, how you resolved it, and what it cost.
Thanks
Matt
Thanks
Matt
Seems to be in sync with revs, which leads me to almost think its one of the accessory pumps...water/power steering. I am not getting any of the rev drops or transmission slips that would normally come with a torque converter issue.
I checked the level of the power steering fluid and it seems to be ok...about half of the bulb is full. And the noise doesnt seem to change or happen when sitting still in the driveway and turning the steering wheel.
My Ride: 2006 BMW 550i
you could remove the belt and BRIEFLY run the engine a bit, and see if the noise goes away. the car may throw a code for no voltage from alternator. not sure if it would reset on own. and while you have the belt removed, spin all the accesories and pullies by hand to see if any make noise.
My Ride: 2008 535 xi, Comfort Access, Cold Weather, Nav, Parking Sensors, Logic 7
Same with mine. Dealer told me that it's normal when the AC is on. It is quite annoying. My wife's '05 MDX makes no noise like that when the AC is on. Oh well.
spediegunz
08-30-2015 09:43 AM
