Loud Knocking!!!
So when I'm driving my 04 530 I hear a lound knocking coming from the rear of my a car if you're inside it seems like right under the center console or just behind it. If you cruise at a constant speed you wont hear it, but as you press the accelerator it will get really wild ( maybe driveshaft related),I had similar probem on my 01 330 so I jacked it up and looked at me guibo and it looks pretty stout so I dont know what else it could be. Any ideas guys/gals
Thnks in advance
Tony
Thnks in advance
Tony
I have about 105,000 miles on it no water tho. Thanks for the input. I'll check those out. U kno a site with a good break down view?
My Ride: 540i
Model Year: 2017
http://www.realoem.com/bmw/select.do
RealOEM is the sight where the driveshaft diagram came from. If you can't get your car on a lift to check the driveline
jack it up, safely, and have a look at those components. Also have a closer look at the guibo. I think it is the most prone
to wear.
Good luck and let us know what you find
to wear.
well Goin to put it on the lift today, and print out a few diagrams amd see what's going on. Hopefully I will se sum visible problem somewhere. Propshaft bushes is a new one. I'll definatly check that out though. Thanx
well guys its definatly the carrier bearing..its shot completely. Thanks for the help. Now I jus have stare at it long enough to figure out how im goin to get it out
tundra
11-10-2016 06:55 AM
Sanjuro
02-02-2005 04:00 PM
