Loud engine noise for my '06 V8
My Ride: 2005 545i - 36k
miro 111's
m5 front bumper and mtech rear
Titanium Silver / Black Dakota
sport package, cold package, Sirius, Nav, Logic 7, Rear Shade, Ipod Integration
it sounds like an exhaust leak IMO - has any work been done on the car recently?
miro 111's
I listened again and it also may be one of your belts is loose, or a pulley is loose, etc - what ever it is it definitely does not sound good
with the car off check to see what your belts look like and see if they feel loose at all
no recent work has been done. I checked the belt after reading CK-e60 DIY on belt replacement the belt is very tight and snug so it's not a loose belt. Not sure about the pulley though. It's driving me crazy but no choice besides bringing it in.
Thanks for the advice.
Thanks for the suggestion guys.
Brought it to a local indy but the mechanic wasn't available, told me to come back on Monday. Just booked an appointment with the dealer for Monday morning but will attempt to remove the serpentine belt later on to find out if the noise does come from a pulley.
One thing I notice is that the noise is the same at both idling and accelerating so thinking could possibly be a bad pulley.
After removing the belt, I discovered that my tensioner pulley is failing, at least it sounds like it is so will need to get the part on Monday morning and replacing it.
A question to those who has done this kind of work before, how does the water pump pulley suppose to sound like? I tried spinning it's a bit tight, not as loose as the tensioner pulley but it does make small noise. Is that normal or is it supposed to be super quiet. I searched online but there is not that much info on it. Lots of video and audio clips and the failing tensioner pulley though.
Thank you for your time.
Richard
Richard
