Loose air bag cloth / cover passenger pillar
Old 02-12-2014, 03:43 PM
code37's Avatar
Default Loose air bag cloth / cover passenger pillar
Over time seems like this cloth comes loose anyone have same problems?
Attached Thumbnails Loose air bag cloth / cover passenger pillar-img_8347.jpg   Loose air bag cloth / cover passenger pillar-img_8346.jpg
Old 02-12-2014, 03:51 PM
tonyb635's Avatar
Have you ever removed this panel? You should take it if and use some 3m spray glue to repair it.
Old 02-12-2014, 04:12 PM
code37's Avatar
i've never removed it before
in my opinion it seems like after i put it through a car wash, where the servicemen, wipes the dash board, and window,
it overtimes pushes the cloth out and off the pillar. can the pillar be removed with out deploying the airbag or causing an "error" message in the system?
Old 02-13-2014, 07:03 AM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Not sure how that happens. Looks like the fabric on the pillar trim piece. You'll like this video:
Old 02-13-2014, 07:39 AM
tonyb635's Avatar
One suggestion when removing the panel or any panel in your car. Do not use screw drivers and tools such as shown in this video! They make plastic interior removal tools and most of your parts stores carry them or you can order them on line. When disconnecting the clip at the mid point the plastic tool will really help as they often come in a kit with various sizes and shapes. You can get underneath the point where the clip is an pry it out much safer. Otherwise you risk snapping the substrate when you begin the pulling and twisting motion as the video suggests. Once you break or crack the substrate you are hosed because you will not be able to hide that problem well. A screw driver used as a pry tool has no place in our car and can cause SOOOO much damage before you realize it...
Old 04-23-2014, 03:29 PM
code37's Avatar
Arrow
Originally Posted by tonyb635
One suggestion when removing the panel or any panel in your car. Do not use screw drivers and tools such a...... it...
great advice & awesome video. Would you happen to send a link for the tool whether is amazon or ebay? Thanks
Old 04-23-2014, 04:20 PM
pcy
pcy's Avatar
5 Piece Auto Trim and Molding Tool Set
Old 04-24-2014, 09:40 AM
code37's Avatar
Thumbs up Thank You all, you are the best
done. went to local store and bought the trim molding set & adhesive & a brush.
Rather than spraying, i'd recommend brushing on a medium to light coating of the adhesive to the area then let sit dry for 10-15 minutes.
Attached Thumbnails Loose air bag cloth / cover passenger pillar-e60-pillar.jpg
Old 04-25-2014, 05:16 AM
plowery21's Avatar
My Ride: Alpine White 2010 535 M-Sport
Great post! Have the same issue and I have been procrastinating taking it to a trim shop.. Now ill just do it myself. What type of adhesive did you brush on??
Thanks to all for the input and DIY video on this post.
Old 04-25-2014, 08:24 PM
code37's Avatar
i used 3M fabric/cloth adhesive. target, auto zone, o'reily's should carry it.
Quick Reply: Loose air bag cloth / cover passenger pillar
