Hi All.
I have an e60 LCI with the Logic 7 speakers. I have never been overly impressed with them, i'd say they are good but not great. I have seen posts on this site comparing the two (pre LCI Logic 7 was apparently very good) and wonder if it is worth purchasing the speakers, amp and subs to upgrade the sound system? I am awaiting prices for the parts to see what the cost would be, but is it worth doing or should i go for an aftermarket option? I am keen not to change the internal look of the car, and definately do not want to cut wires (simple swapping of items) or run new earth, power or whatever around the car. I also want to ensure the standard bings, bongs, bleeps and other noises (i.e Sat nav) still work correctly and are not too quiet or loud - something i have read in the past but not sure if still relevant. If i do proceed with the retrofit, then will i need to get the car re-coded to recognise the Individual Audio or will it just work? And when i do upgrade the CCC to a shiny CIC, will there be any problems then? Any advise, comments or suggestions are welcome. Ta, Darron |
My boy put a 10" bass box In his 645 with and amp and it sound real good not to much bass either
Originally Posted by SmG-Deuce
(Post 1324046)
Be warned : The difference between L7 and Individual is more than just Amp and speakers.
Originally Posted by bruce_miranda
(Post 1324456)
It's all under warranty.
The injectors and HPFP are part of the recall. For the turbos, I complained that the car was making a bit of a clicking noise. especially when cold. It was diagnosed as noisy wastegates. After consultation with BMW and measuring the freeplay, they decided to replace both turbos. With 35k miles on the car, and the warranty expiring this fall (although I do have CPO beyond that), it's nice to get these covered now, but must be costing BMW a fortune. |
Originally Posted by mostroad
(Post 1324528)
The injectors and HPFP are part of the recall. For the turbos, I complained that the car was making a bit of a clicking noise. especially when cold. It was diagnosed as noisy wastegates. After consultation with BMW and measuring the freeplay, they decided to replace both turbos. With 35k miles on the car, and the warranty expiring this fall (although I do have CPO beyond that), it's nice to get these covered now, but must be costing BMW a fortune. wrong thread me thinks ;) I was happy for a moment thinking there was a response for me! |
Hi Guys, any more thoughts on this?
This may be a non-US question as reading other forums suggests the individual audio is not available over there. perhaps the L7 in the states is the individual here? Anyway; Can it be done? Is it worth it? or, should i simply look at the aftermarket systems? would appreciate any helpful comments... |
chk sig
Originally Posted by vishwen
(Post 1324873)
chk sig
yours or mine? i know what mine says and yours says that your car is gone but not forgotten? |
