lm2 upgrade stuck by starting panel
My Ride: LCI M5 Alpine White III
Engine: S85
i'm starting to upgrade the LM2 but, get stuck by the panel i want to remove, i know there are four screws underneath, but i can take the right side out, it seems stuck in with the right foor panel or whatever it is. I use red circle to circle it out.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: E60
Model Year: 2010
I'm also in the process of doing this.
It has a small trim that has to be removed. It just slides backwards and pops out. Then you'll see 1 more screw to remove, then the panel will be able to come out. Would you be able to assist me in the bmw coding software?
mishka69
03-18-2016 04:54 PM
