Little Help on E60
Hi Guys!
Im new to BMW with a E60 2005 I recently bought. And couldnt feel any better!!
I would appreciate if you guys can help me a bit with a recomendation on the wheels, I just ordered a new set of rims that have this info:
Rear: 19x9.5"
Offset: Front: +40
Rear: +40
Bolt Pattern: 5x120mm
Hub Bore: 72.56mm
But I didnt know I might need a spacer, plus the seller didnt know either, so the question is, do I need spacers? and how do I buy them?
BTW I am in a middle of something and its very possible I change my 525I 2005 for a 525I 2009, are they the same? or this wheels wont fit on the 2009?
Sorry for the ignorance!
Thanks a lot!!
Rear: 19x9.5"
Offset: Front: +40
Rear: +40
Hub Bore: 72.56mm
Thanks a lot!!
that is correct, you will definitely need spacers for a 525i regardless of what year the 525i is. those offsets are more appropriate for the E60 XI AWD models. for those sizes to fit on a non-XI RWD model, I would recommend about 25mm in front and 20mm in the rear, which we do carry if interested.
jasonkhasnofriends
Apr 27, 2015 12:41 PM
