License plate light malfunction
My Ride: Alpine White 2010 535 M-Sport
Stock lights, I received the Right License Plate Light Malfunction message last week. Looked and the light was out. Started driving again and light came back on only to receive the message again 10 miles later. Days later, I got, Left plate light malfunction. Pulled over, it was out (right was on
)...tapped on it, opened trunk and shut...it came back on. Since then I have received the Right message a dozen times. It appears to be down for the count.
Main question - Is this a bulb issue or a wire harness issue? I have ordered the LEDs but if its a wire problem that wont help. So do I need to take it in to BMW under warranty for them to look at, or is this a common occurrence with a bulb failure and the LEDs will be just fine. Thanks for everyone's input.
My Ride: 2014 535 Alpine White
Ordered the LEDs from John @ motorcepts. Was told they were error free. Also getting the interior lights from him as well. UPS tracking says they will be on my doorstep tonight. Will get working on them ASAP.
Yes, stock bulbs acting up. Thought they were burnt out so I ordered the LEDs, but the behavior of them made me wonder if I need more than new light bulbs.
My Ride: 2021 BMW 540i XDrive Bluestone Metallic on Ivory White Napa Leather. Packages: Executive, M Sport, Parking Assistance, Luxury Seating, Shadowline. Options: M Sport Brakes with Blue Calipers, Body Color Rocker Panel Blades and Spoiler, Heated Steering
Model Year: 2021
That's wierd!
To be on the safe side, since you're still under warranty, I would let the $tealer check out the wiring/ connection/ bulbs before you install the LED's.
I also bought the OEM LED's with the adaptoers from Bruce Miranda. I will install them shortly, since I just passed my warranty period.
How much for the interior lights? i have to get those next and i live in NY and not to far from Motorcepts.
the wires are damaged or broken at the right trunk arm. open trunk Remove right side panel. look at the wire bundle that goes into the right trunk alarm.
My Ride: BMW 550i
Try replacing the original bulbs (if you still have) to see if you still have the error message?
