License Plate Bulb Housing
Hey All,
I was installing some LED License Plate Bulbs and cracked the housing on the left side, which resulted in having the broken pieces as well as the OEM bulb fall into the interior of the trunk lid. Now I have a big hole on the left housing, which will get wet if I leave it like that. Is there a place I can go to get this piece replaced? It seems really miniscule, but I just got the car so little things like this kind of frustrate me. Any help, advice, recommendations on where I can get a new housing would be greatly appreciated! Also, I am getting a License Bulb Malfunction message on the Rt. Bulb...have any of you had this issue and found a remedy for it?
Thanks,
Thanks,
Originally Posted by JetCFI' post='939289' date='Jul 11 2009, 03:13 AM
Hey All,
Thanks,
Thanks,
I forgot his name.... someone will chime in
i changed out my license plate bulbs to white and I always get the light bulb malfunction message. They work fine though I think the error message is normal if you change out the bulbs to something different.
you could try and stop by your dealer (parts dept)to get a new bulb housing, as I believe you are asking for that and not a bulb upgrade....
but as stated, if you were/are planning on getting a bulb upgrade anyway...
http://forums.e60.net/index.php?showtopic=77209&hl=
or
http://forums.e60.net/index.php?showtopic=70638&hl=
or
or
or
BrandonSS
Apr 19, 2016 05:11 AM
kcrokin
Sep 3, 2015 10:38 AM
