Left steering wheel controls and horn not working...
Old 05-15-2013, 10:49 AM
ldesouza's Avatar
Default Left steering wheel controls and horn not working...
So I noticed last week my horn stopped working and then today i noticed my left controls (volume, phone, and voice control) inst working either Im about to take the steering wheel off and check all the connections but does anyone have any idea as to what it could be?
Old 05-15-2013, 04:12 PM
Razzy530's Avatar
My Ride: 2007 E60 530i 6 Speed Silver Gray
Engine: N52
Battery?
Old 05-15-2013, 04:57 PM
ldesouza's Avatar
Originally Posted by Razzy530
Battery?
Would it cause only these things to act up? Everything else is working fine.
Old 05-16-2013, 05:12 AM
DavidF's Avatar
My Ride: 545i sport
My guess is the "coil spring cartridge" is faulty. Some call it the clock spring, slip ring, etc. Located in steering column just behind steering wheel.
Old 05-16-2013, 08:34 AM
ldesouza's Avatar
Is there a way to check? The right buttons stopped working too
Old 05-20-2013, 03:07 PM
ldesouza's Avatar
Is it a bad idea to buy a used clock spring? Dont want it to break on me again.
Old 05-20-2013, 04:03 PM
AchtungE60's Avatar
My Ride: E60 530i
Don't let people point you to jump to conclusions. I let my car sit for 4 months and the horn wasn't working. I don't know if steering wheel knobs worked or not, didn't check. I would doubt the two are related. Anyway I unplugged the horn and plugged back in and it was fine. Again, i doubt the two are related. Do not make a simple situation worse right now by taking unsound advice. Check electrcal connections and fuses first. Always.
Old 05-21-2013, 04:32 AM
boosted5's Avatar
I've got the same thing after an engine replacement. I will let you know what it is if I figure it out, or just most likely take it back to them seems like they didn't plug something back in.
Old 05-22-2013, 07:30 PM
ldesouza's Avatar
Ill check the connections. Thanks for the heads up
Old 05-22-2013, 07:31 PM
ldesouza's Avatar
Would highly appreciate it man. Thanks. If I find anything ill let you know to.
Quick Reply: Left steering wheel controls and horn not working...
