Left side low beam and adaptive leveling fault.
My Ride: 2008 bmw e60 535i, 6 speed manual, sport package
Hi! I'm new and only asking after I've searched forever on all the 5 series forums. It's a 2008 535i if that matters at all. After my wife took it to a car wash the passenger side headlight filled up with condensation and the low beam and auto leveling for that light no longer worked. I replaced the low beam light but it is still not working. While I had the light out I noticed the small black box in the headlight unit under the low beam cone was open slightly. It has white connectors on the top and sides of it. It looks like their might be a circuit board inside. Is this a serviceable part or do I have to buy a headlight assembly? How would I check if the voltage outputs are correct (what voltage should the connectors output)?
Thank you all in advance and happy motoring!
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Did you let it dry out first before buying parts? I would dry it out check the cables and connectors for cracks, corrosion, burn marks then try again to see if it works.
I don't think changing the bulb would correct both errors so there is still condensation in the assembly.
What I haven't done is switch the modules (metal boxes on the bottom of the headlights) from the functioning driver side to the passenger side. I'm afraid of shorting out the good functioning boxes.
Is this a valid concern or are those modules pretty robust?
Model Year: 05 530i
Engine: 3.0 M54
The box you are referring to is the HID I believe. That should not be your problem. But if you want to swap them you can. They are sealed and do not short. I believe your issue is water getting inside and creating a short some where. On the leveling mech. and low beam wire. These headlight are known for shorts due to wire contact on the inside. Look inside the circle you change your bulb and inspect every wire. I still think it needs time to dry.
bestofthebest
01-05-2016 07:47 PM
