Left & Right High Beam Malfunction
Old 06-13-2012, 10:07 AM
AUSaxon00's Avatar
I have a high-beam malfunction on both right & left headlights on a 2006 525xi. Both failed at exactly the same time as I attempted to switch from low to high beams. The bulbs are 55W H7 (both high & low beams) and less than 4 months old. I checked fuses F5 and F6 in the glove box and both are intact. A visual check of the high beam bulbs from outside looks like the filaments are fine. Are there any other fuses to check? Is this a problem with the light module? Low beams work fine. Thanks for any help in advance.
Old 06-13-2012, 03:34 PM
AchtungE60's Avatar
My Ride: E60 530i
Odd issue. check to make sure the wires are ok. They're related to one another. How are your fogs?
rodybmw
04-23-2021 08:03 AM
lukieno1
07-01-2015 04:37 PM
JDN
06-21-2004 01:45 PM
sg530
04-28-2004 08:33 PM
08-12-2003 11:41 AM
Quick Reply: Left & Right High Beam Malfunction
