Left Brake Light Failure
Old Apr 18, 2009 | 01:57 AM
selbycy's Avatar
Anybody have this problem before?
I have a message in the I-Drive saying Left Brake Light Failure but when I press the Brake pedal the brake lights come on?
How can I get rid of this message?
Old Apr 18, 2009 | 02:06 AM
BLooD's Avatar
i some times have a problem with my parking lights doing this, its not allways the same one either
Old Apr 18, 2009 | 02:10 AM
aresh's Avatar
Also have the same problem bt happens once in a while randomly
Old Apr 18, 2009 | 11:31 AM
selbycy's Avatar
Mine has said it continously for 2 days.
Did yours stay like this and turn off again? Or is it just randomly coming on sometimes?
Old Apr 18, 2009 | 12:19 PM
CWS530's Avatar
My guess is your light is about to go. On a previous BMW, I had this same issue. I was driving near the dealership on the second day, and just popped in. They replaced the bulb (under warranty--obviously I could have done that myself otherwise), and told me that right before the filament burns, a sensor detects something (I have no idea) and pops the warning so you have a chance to replace it before it actually becomes a hazard. True or not, a new bulb fixed the warning.
Old Apr 18, 2009 | 01:22 PM
aresh's Avatar
mine comes randomly on random days. It probably is going to go out soon, im guessing.
Old Apr 18, 2009 | 01:23 PM
boukehj's Avatar
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
Could it be that one of the two brake lights on either side is broken or loose? The one that comes on only when you brake hard? I recall that most of us have two-stage brake lights? I'm not sure, because I haven't found any evidence that I have two-stage brake lights on my 520d LCI.
Old Apr 20, 2009 | 05:21 PM
virgil's Avatar
My Ride: E60 530d M Sport, Alpine White, 2006, Australian
Model Year: 2005
Ugh! I had this problem continuously with my old e39 323i for about a year. I took it to an auto electrician who fixed it within 30 minutes. He simply added an extra earth wire to the brake light assembly, tucked it under the floor mat and screwed it into the trunk floor. Never had the problem again.
Cheers,
virgil
Old Apr 20, 2009 | 06:53 PM
flyingpuck's Avatar
This happened to me before....pull out the bulb, clean out the socket, reinstall the bulb, and the error message should be gone! When the slightest bit of corrosion is present in the bulb socket, the resistance increases and the error message is how you find out, my local dealership (Rusnak...Losers) immediately wanted to setup an appointment for a repair complete with a loaner car, instead of just FIXING it on the spot!
Good Luck and let us know how it turns out!!
Old Apr 20, 2009 | 07:07 PM
mrfva's Avatar
My Ride: .
Model Year: .
+1. This happened to my previous E39 a number of time. I suspect the same will be with the E60
