Leaking steering rack
Old Mar 29, 2025 | 11:36 AM
arron9999's Avatar
Probation Members
Default Leaking steering rack
Hi All,
I have a 2008 535D and there is a leak coming from the steering rack. Everything else is fine with the rack, still tight and driver straight.
I have 2 questions,
I believe I have the Hydro version, is there a way to chexk this via vin?
And is there a seal rebuild kit?
I have seen videos about replacing the top seal where the steering column connects (this is where mine is leaking) but cant seem to find a seal kit for it.
Attachd picture is not of my rack but shows where the leak is coming from
Any advise welcome
thanks
Old Mar 29, 2025 | 12:40 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Realoem
Old May 6, 2025 | 12:31 PM
0007_JS's Avatar
My Ride: 528i 2009 (E60)
Mine is leaking from the same place. Have yet to do it yet because it's a small seepage and I only have to top off fluid every thousand or two miles. I believe I read it's possible to pull the servotronic unit off without dropping the subframe+rack, but be prepared to have to drop the subframe if it doesn't work out. You don't need any special tools to install the seals and you can get away with just removing/installing the main one (input shaft seal) with the right sized socket.
Here is a seal kit, send seller your VIN to confirm fitment (these are supposedly high-quality seals made by SKF): https://www.ebay.com/itm/26667156124...mis&media=COPY
ripley
Jun 14, 2022 02:48 PM
ghall
Sep 24, 2016 11:51 AM
GT-ER
Oct 8, 2014 09:21 AM
catuta1981
DIY: Do It Yourself
Mar 12, 2010 03:55 AM
Schu Dog Nite
Oct 11, 2009 07:23 PM
