Lcm lm ii
anybody can tell me does this work to retrofit the headlight with AE on? or do i really need to pay 400 to get a new one?
BMW E60 E61 E63 E64 E65 E66 5 6 7's LCM Light Control Module LM II E6X LWR Xenon | eBay |
Try going to: REALOEM.COM Input your vin number and drive down to lighting. Find the part and confirm the OEM part number and the acceptable replacement numbers. See if any of the numbers are a match...
Good luck. |
For vehicles with
Xenon Light S522A=Yes and Head-up display S522A=Yes and Adaptive Headlights S524A=No 61359112630 $449.27 ENDED 61359116254 $449.27 ENDED 61359153272 $449.27 ENDED 61359154943 $459.24 ENDED 61359180756 $459.24 ENDED 61359192641 $488.76 ENDED 61359203081 so i need to buy 6139203081 or other part number that above? |
If your information is correct, then any of the part numbers listed word work and be available as used parts. If you were going to a BMW dealer or republican on line new parts vendor, then only the latest, non superseded part would generally only be available.
I seem to remember reading someplace that all US models with Xenon's came in Adaptive=Yes. Not sure if that changes the part numbers.
Originally Posted by yiqiuc
(Post 1571888)
the one i post earlier is mistake, the one i want to post is
For vehicles with Xenon Light and Adaptive Headlights and Head-up display S522A=Yes S524A=Yes S610A=No 05 Light module 1 03/2005 09/2006 61329112629 $449.27 ENDED 05 Light module 1 03/2005 09/2006 61359116260 $449.27 ENDED 05 Light module 1 03/2005 09/2006 61359153273 $449.27 ENDED 05 Light module 1 03/2005 09/2006 61359154944 $459.24 ENDED 05 Light module 1 03/2005 09/2006 61359179186 $459.24 ENDED 05 Light module 1 03/2005 09/2006 61359192642 $488.76 ENDED 05 Light module 1 03/2005 09/2006 61359203082 |
and i'm kind new here i'm not sure how to pm work out.
I don't know what year your e60 is. If it is a 05 then the light module would be a LM1 light module. Halo lights can not be used as daytime ranning lights.....
However if your e60 is a 07 model year then you want a LM2 light module, which will allow you to have halos as daylight running lights and several other functions not available with LM1. For that matter, if your e60 is model year 04-06 upgrade to a LM2 and code in options not available to original build. |
(Post 1572053)
