LCI RETROFIT HELP PLEASE
LCI RETROFIT PLEASE HELP SOMEONE!!
Hello,
First, my name is Andrei, i've got a 530d from 03.2004 xenon headlights, cornering ligths, dinamic drive.I want first to change first the tail lights to lci.I can buy them original BMW lci tail lights for a good deal.From what i've read of I got two chances1.change LM to LM2(i beleve) or 2.buy bruce miranda's cables.
So far so good, but here is my question:if I got the chance to buy the LM from a BMW after 03.2005(i don't know which kind of LM is it(meening LM,LM1,LM2)and i can't get any serial nr.of it, I gest know the manufacturing date),should I buy it?does it help?and later can I change my headlighte also and use this module to make them work?
I've read a topic wich said that by changing certain pins(cables)in someLM(don't know which type of LM 1..2...3)you can make the tail lci work and also the lci headlights can work properly( no faults, no flashes,no bab light,etc)
First and first i want to change the tail lights, so what should i do?
PLEASE HELP, I'm CONFUSED!!!
THANK YOU.
Hello,
THANK YOU.
Hello,
THANK YOU.
Hello,
THANK YOU.
Originally Posted by Cwest' post='899788' date='Jun 3 2009, 02:30 PM
Let see if Bruce Miranda and (Rival) BLASTIWI and some members can chime in on this subject cause i have the same year built car I would love to know it also. ![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
The problem with the BMW retrofit route is that you MUST do the headlights and the tail-lights together. Failing which you will loose functions like the angel eyes etc. You MUST also change your LCM if you have a car that is older than 2007.
But in another topic i've read that if the car is over 03.05, it is possible to change some kind of connectors(pins)inside the LM and it works.
Also a BMW dealer told me this stuff.Do you know anything about it?
Anyway can you please tell me bruce how can i buy the cables for the retrofit lci?
Thank you.
Originally Posted by BMWWW' post='899812' date='Jun 3 2009, 10:48 PM
Thank you a lot for the info.
umnitza
11-03-2015 02:58 PM
