Kinda stumped. Any advice would be great. (electrical)
I think its that bumper causing all of your issues...! Ha, I know when I replaced my battery a couple years ago I researched it quite well. Often when I called carious places to ask about a replacement they always said they had it but when I got there it was not quite the same. Always the CCA and CA were a little different. Even when I went to AZ to get it, they said the same thing, or their system did. I finally asked the counter person to see if they had a battery with these exact specs. He left and returned with the battery, install it and every thing has been ok since.
My Ride: 545 modded the F out
Just a warning......... if that voltage runs(spikes ) over 14.8 during running the car your regulator needs to be replaced as any voltage exceeding the 14.8 figure will damage your new AGM battery as well.
Mine was spiking over 15 volts especially in cold weather and caused all kinds of sh%t even screwed up the software over time and had to reprogram whole car.
My Ride: 535
Model Year: 2010
Are you 100% sure your car was reprogrammed at some point for accepting an AGM battery?? YOu car originall had to have come with a white FLA battery. Just making sure...Also did you try charging the battery from a trickle charger and see if it works better?? Try that.
The other thing you could look into is Steering Angle Sensor.. it might need to be reset or replaced..
As far as the steering wheel sensor, I hadn't even thought of that. Like i said tho. it happens literally like clockwork after having driven like 20 plus miles. It makes a lot of sense to me that these two fault codes appear as the first ones as the system starts to regulate itself by cutting out the lesser priority items first if electrical issues are involved so I'm really hoping it's just the stupid alternator. 10 years for an alternator seems about right I guess.
Thanks again tho
My Ride: Na
Yea bro, that's how my car was. Few months ago it didnt started and just time after time it would be a few minutes until it starts. I'd bet $20 it's your "integrated power supply" 20 minute fix. I just bought my part from eBay. Haven't had a issue the past 2 days. $20 it fixes it! Haha
I understand why dealer charges so much for this ........
I know exactly what your fix is. You got to many mods in your headlights. You need to go back to stock. I'll help you. Lets swap headlight assemblies with my stock ones. Your problems will go away. LOL
My Ride: BMW Alpina B5 -05
