Key Programming
My Ride: 2005 BMW 545i
Key Programming
I just recently bought a 2005 545i. It came with only one key and that was a normal diamond style key with working lock and unlock buttons. Because I only had one key I had to buy another and decided to buy 2 upgraded flip keys. I went to a key place and they cut the key, put a new chip in it because the old one wasn't working, and then programmed it and now it can start the car like its supposed to with no issues. Everything works fine except the buttons on it, the lock, unlock, and trunk button don't actually do anything and he tried all the sequences to get it connected but it didn't work and when he gave up I spent hours doing research and hours trying all the sequences I could find online. Eventually I gave up with that and decided maybe it was something wrong with these keys so I bought two more from a different seller on Amazon and looked at tons of reviews that said it was great but when I tried all the sequences and everything on those two they didn't work either. I've tried everything I could think of and now I have 4 keys lying around with buttons that don't work. Its not the batteries, there's a light that flashes when I press buttons. The two new ones aren't cut and programmed and I didn't want to waste money if it wasn't gonna work, so I was doing part of the sequence with the old working key and part of it with the new one similar to this (
) but with a different new key. I have no idea what to do, if anyone has any ideas that would be great, Thanks!
My Ride: 05 BMW 525
Engine: M54B25
You can see on the right side that mine says 315 also I looked up my VIN and the same thing came up
Look under radio frequency
My Ride: 05 BMW 525
Engine: M54B25
I bought the keys off of Amazon so I assume they are very similar to those found in eBay. And yes, of course the remote uses radio to open the doors so if your remote doesn't have the same frequency as your car then it won't pick up any signal
I cant find a VIN lookup site that tells me the frequency but on the original diamond key it says 315 MHz on the back and both sets I bought from amazon and eBay also said 315
There's probably more to it than just simply matching the frequencies. Could be a compatibly issue with that particular key.
