Key fob woes.
Old Apr 29, 2015 | 02:44 PM
160THSOAR's Avatar
My Ride: 545I
Default Key fob woes.
My key fob does not work at all....and It has not since I purchased the car. I got a good deal on it, so I wasn't too concerned about the key fob at time of purchase. the actual key works for locking, unlocking and ignition...however the remote key fob functions are a no-go. After spending quite a few hours searching forums, I decided that maybe the rechargeable battery inside the fob had just died out...it is 11+ years old right? So I cut open the fob, which is a lot easier than others made seem, I had it open in about a minute with a carpet cutter blade. Tested the battery with a multimeter. 3.08 volts ....the battery was good...and as far as I can tell , is still charging when inserted into the ignition. Im pretty sure that the issue is with my car somewhere not the key/fob/battery.
Any suggestions on what to troubleshoot next?
my next step is to check fuses...maybe should've been my first step but whatever...
04' 545i, No-CA (diamond key fob)
Old Apr 29, 2015 | 03:43 PM
160THSOAR's Avatar
My Ride: 545I
Almost immediately after posting this a friend of mine noticed the solder on one side of the battery had broken...quick solder job annnnnnddddd, FIXED. Just a tip for anyone with a suddenly unserviceable key fob. Ill be purchasing a new case for the key soon, and transferring out the circuit board. Still a lot cheaper than replacing my key through the dealership :/
Old May 1, 2015 | 08:29 AM
Marine0369's Avatar
My Ride: 2009 535i X Drive Premium
My fobs don't work unless I am within about 2-3 feet of the rear of the car. The stealership told me it is because of the tinting on the windows. Any thoughts on that?
Old May 1, 2015 | 02:10 PM
Tetonfiber's Avatar
My Ride: 535i XDrive Touring
Model Year: 2009
Engine: N54
I had a similar issue with my FOB. I had not remote lock. It turned out that the vehicle battery was dying. I replaced the battery and the FOB began working straightaway. The good news is these cars will warn you that your battery is going to fail you very soon.
Stuboski
Nov 5, 2021 06:58 AM
Wonky
Apr 12, 2016 08:15 PM
Johnny B
E34/E28/E12 Discussion
Dec 25, 2015 05:33 AM
Tsubasaftl
Sep 12, 2015 01:34 AM
stylinmike
Sep 1, 2015 04:55 PM
