Hi guys, maybe someone had similar problem with k-can line. Many modules have error, car sometimes run verry well, but sometimes it’S just get crazy, wippers starting to wipe, dasboard just turn off and turn on again, ccc too, and on dashboard red dot appears, when car stops doing all the stuff the rod dot disappear, and everything starts working just fine, but when you check with pc, you still see all modules with failed k-can
