Just bought an '08 BMW 550i MSport and already have an IDrive prob
#21
My Ride: 2005 545i Black Sapphire - Fully Loaded
Model Year: 545i 2005
take a look at the picture of the CIC on this link. your CCC fuse is located on the same spot.
http://cgi.ebay.com/ebaymotors/Brand...fAudioQ5fVideo
#22
Yes. It is located at the site of the quadra lock connector
Great! Thanks so much for the photo, I will test the fuse tomorrow at the dealership when they remove the CCC. I think the fuse blowing is my last resort, otherwise I'm paying the full cost of replacement.
#23
My Ride: 2005 545i Alpine White Premium package, Sport package, Nav, HUD, PDC
Good luck! I hope it all works out. This forum is a gold mine of great help and resources. Just wanted to say congratulations on the purchase and welcome to the forums.
#24
Thanks for the welcome! I think I will be a regular on here from now on.
R9NDY I'D LIKE TO THANK YOU VERY MUCH!!!! I went to another BMW dealership this morning, and it was the fuse that went!!! It only cost me 1.5 hours of labor, and the fuse cost a couple dollars. As soon as I went in to see the Service Manager, I specifically told him I would like to see the fuse tested in front of me. After spending 4 hours at the dealerhsip they finally told me the fuse had gone.
Thanks to all of you for your input, your help cancelled out the other possibilities. The fuse behind the CCC module was my final resort. I did not know it existed until R9ndy pointed it out. I saved $1500.
NOW... The first BMW dealership I went to charged me 2 hours of labor and they diagnosed the car with needing a brand new iDrive system. Should I go back there and request a full refund only, or a full refund and make a complaint?
Thanks so much guys! I owe you one.
#25
My Ride: E60 M5, F85 X5M
I'd definitely go back to the first dealer and squeeze something out of it even if it's just credit or goodwill for the next visit.
#26
Glad it all worked out!
Yes, you should contact the first dealer and see if they would refund or at least give you credit for a future visit. It can't hurt to try. Just remember to be respectful about it. I doubt they were intentionally trying to screw you out of money. It may have just been something a newer tech may have overlooked.
#27
Ugghh... Another problem. I received the car from the dealer this afternoon and started up the car on 3 occasions. The iDrive worked well without any problems --I used the radio and nav system.
On the 4th attempt, my iDrive is attempting to boot, and the monitor displays the "BMW" start up screen. It attempts to boot into the main menu, but then gives up, turns off, and starts the cycle all over again. This happens repeatedly every 2 minutes.
I tried restarting the car a few times, and tried the 3 finger reboot a few times, and still, I'm having problems with the software booting up. Is there anything I can do to get it to boot up? Maybe disconnecting the battery terminal for a few minutes and retrying after that?
I don't want to go back into the service department. They kept me there for 4 hours today just to change the fuse. This is frustrating.
Help out once more guys, lol....
#28
I tried disconnecting the negative terminal on the battery for an hour and then restarting iDrive. Still unsuccessful.
I don't understand how the iDrive could work for a couple hours, and then not boot up after I left it parked for a couple of hours.
#30
full car software update should be costing you labour of 1 to 2 hours max, this is full car, not just CCC. Just CCC could be cheaper but I doubt any discount may be made on this. CCC takes the longest.
Not sure you might want to try warranty here (if still left) as it has been only worked by dealership and the problem coin caused was blown fuse.
