Ive Got WiFi in the car, now what...
So Ive fairly well teched out my car.
Its a 2004 545i, but has the full CIC Nav Combox upgrade, making it essentially a 2012. All of which I love.
Recently now Ive put my own personal hotspot in the car, using the power source in the glove compartment to power a portable router & a Verizon 4G dongle.
Love this too.
To run the CIC integration I have an iphone 4 with no cellular data (killed the plan) & running wifi. With the router set up, I now have a great experience with BMW apps I want:
Stitcher, MOG, Pandora all rock. The BMW canned apps from their own app are there as well and just ok.
My question is:
Is there a way to get the wifi from my router to feed the CIC directly? A retrofit for a wifi adapter?
Currently the CIC is supposed to get its data connection through the iphone I have attached using hotspot/tethering activated. BUT since I dont have cellular anymore I cant do that. Ive looked into it extensively, and even if jailbroken, the iphone cannot both recieve & share the wifi signal (even in USB mode).
Anyone smart enough to know if there is another way to pipe my wifi directly into the CIC?
Love this too.
My question is:
Miranda to the rescue:
There is a solution...
Can you retrofit a wifi adapter into the CIC? - 5Series.net - Forums
Click on the link in my signature below & you will get the full down low.
I used Bimmertech & Patryk whom youll hear about a lot on the forums & am thoroughly satisfied & happy with the work & investment.
As you can see, Im looking for ways to now expand what I have into doing more.
My Ride: BMW E60
Model Year: 2016
The above method seems more permanent and possibly the best if you decide to keep the same set up.
However, I do believe that the jailbroken app MyWi is capable of having the iPhone connect to a wireless network and share it. Might be worth trying out before start taking things apart.
Nicely done Simon, I searched high & low for a software option like this & missed it.
Definitely going to try this prior to cutting wires. I am of limited capability in that area![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Will report back if this whole thing works out.
Awest91
09-17-2022 11:05 PM
