so i just got a new 530i (august make)
in the manual, they are talking about 2 AUX ports - USB and standard Jack, wich you use (both) to connect an iPod but my car only has a jack port. any idea why no USB? would i be able to connect iPod without the USB port? :( |
Check the glove compartment. Some say there's a USB connector in there....
but strangely, the pic in the manual shows them both one beside another (where the back passengers Air Conditioning panel is) |
god dammit.
i read some threads and it seems that a USB port is an "option" any idea what the AUX jack if used for then? |
Originally Posted by Miikka' post='669883' date='Sep 15 2008, 01:44 PM
It is standard Aux-in, you can connect iPod from the headphone connector to that one and then select Aux-in from the iDrive to listen your iPod.
will I lose any music quality or any other options? would i need any special cables to connect it? (ipod headphone exit <--> AUX) thanks. |
Originally Posted by Kuat' post='669884' date='Sep 15 2008, 02:48 PM
how is it different from the 6FL then?
will I lose any music quality or any other options? would i need any special cables to connect it? (ipod headphone exit <--> AUX) thanks. What you have is the standard auxiliary input with no USB or iPod interface... |
i see the panel inside the armrest compartment where the iPod/USB pots should be
do you think the dealer should be able to install this option? |
do you think the dealer should be able to install this option? yes they could and i would say go for it. it really is worth it with the USB and iPod interface. i love mine and ive also noticed when i undocked my ipod and stuck in my thumbdrive(listen to music from thumbdrive sometimes) that iDrive automaticaly copied ALL the song from iPod to thumbdrive hmm weird but i dont mind. |
