INPA Requested control unit not found
1 Attachment(s)
I'm trying to connect my ai bag module with inpa and i received this error
are you able to access any other control units?
yes.... yesterday i chek my transmission without any problem
what year and model is your car? where did you get your cable from?
tomorrow I'll hook my laptop up to the car and see what sequence I go through to get to the airbag control unit. Not sure why you can't access it. What made you want to access the airbag unit, are you havinan SRS problem? |
I have E60 525i 2004...... i bought this cable at ebay.com it cost only 23 USD....
when i start my car i drive send me a message about passenger restraint system and belt tension malfunction too, also air bag and belt warning lights are displayed |
same problem, when i tried it today. had to Load INPA program, directly from C/drive.
Originally Posted by a10warlord
(Post 1554262)
Can you not access the SGM? I have been plagued with the same iDrive messages and you can clear them in the SGM communication module. When you check for all errors what is the fault code? anything like this below? E R R O R M E M O R Y ----------------------- Date: 14.12.2014 12:32:13 Model: E60 Scope: all control module JobStatus: OKAY Quantity: 36 ----------------------------------------------------------------- ADR Gen. name JobStatus 1B VVT ERROR_ECU_SERVICE_NOT_SUPPORTED 1E VVT2 ERROR_ECU_SERVICE_NOT_SUPPORTED 90 VIRTSG90 ERROR_ECU_SERVICE_NOT_SUPPORTED 91 VIRTSG91 ERROR_ECU_SERVICE_NOT_SUPPORTED 92 VIRTSG92 ERROR_ECU_SERVICE_NOT_SUPPORTED ----------------------------------------------------------------- ADR Gen. name JobStatus Number of errors• Error code Kind of error 00 ZGM OKAY No Error stored• 01 SIM/SGM OKAY 2 Error stored• 93CC 20• 93CD 20• 02 SZL OKAY 1 Error stored• 94E7 20• 05 STVL/TEFA OKAY No Error stored• |
