INPA and NCS help :0(
Old Aug 31, 2011 | 11:59 AM
the_big_1's Avatar
Hi All,
I have used NCS and INPA on E46 for a while, now I have an E60 12/2007 build.
I have purchased a new cable, a "K+DCAN" interface.
I have reinstalled INPA and NCS from scratch.
I have the OBD.ini in the following directories (Copy below):
C:\
C:\Windows
C:\Windows\System
C:\Windows\System32
C:\EDIABAS\BIN
C:\EDIABAS\HARDWARE\OBD
My Environment variables PATH is set as:
%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShel l\v1.0\;C:\EDIABAS\Bin;C:\INPA\BIN
The Ediabas.ini is below on the interface:
The obdsetup.exe reports all ok.
But I start INPA, have batt and ignition circles on, cable plugged in usb but not the car. If I unplug the cable they go off.
No matter what unit I try to read I just get errors of "No responce from unit" and busy is showing bottom left of INPA. The LED on the lead flashes intermitantly.
If I try NCS expert I get "VIN Incorrect error"
Really stuck guys, any ideas????
; Description : Connected diagnosis interface
; Default = EDIC
Interface = STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
I have the OBD.ini as the following:
[OBD]
Port=Com1
Hardware=OBD
RETRY=ON
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
sxybeemr
Jun 20, 2023 10:13 AM
Tymm
May 30, 2016 06:23 AM
Wonky
Apr 12, 2016 08:15 PM
Brammer
Nov 4, 2015 01:02 PM
Bounce
Aug 31, 2015 10:04 AM
