Increase EMISSIONS
I have a BMW 2004 545i and I am experiencing codes P2187&89 that are pending when I got heavy traffic they become real codes of increase EMISSIONS any thoughts on what the problem could be
Check for vacuum leaks. I would do a smoke test. It could be a number of things that could be the issue.
1. Do smoke test (this way you can check the whole system for a crack) 2. Check DISA 3. Check MAF 4. Check o2 sensors 5. Check Evaporative Emission Ventilation Solenoid Many things can cause it and only you know the history of the car. If the hoses have never been replaced or the DISA then I would start there. |
Increase EMISSIONS
Originally Posted by jeff1949
Skipped over you had the 545i. You don't have one on your car
Increase EMISSIONS
Increase EMISSIONS. What does DISA stand for pardon my ignorance on some of these verbage
Increased emmisons
What does DISA stand for definition |
Increased emmisons
Increased emmisons what does DISA stand for nobody home today
You do not have one in your vehicle. It's called a disa valve well at least the one I'm talking about.
If you want to look it up it's called an intake manifold motor (drive)
