Ignition coil and spark plugs - request
Hello folks,
I have a 06 530xi (67k) and had to replace one of the ignition coils recently that misfired.
(Could have replaced all six but this was urgent and I couldn't shop around for a good price; was forced to buy one for $65!)
I intend replacing the remaining coils and thought of replacing the spark plugs also when I am doing it.
Would greatly appreciate some suggestions on the same:
- should I stick with the OEM coil and spark plugs?
- if you have recommendations, can you provide the part #s and link please?
Thanks in advance!
Thanks in advance!
Yes, I'd recommend you to stick to the OEM coils and plugs.
Check RMeuropean dot com (shipping is free with orders over $75).
Check Amazon for coils. Bosch coils for around $27 each. Eligible for free shipping.
My Ride: F10 M5
Model Year: 2013
Hello folks,
Thanks in advance!
Thanks in advance!
I saw a few on amazon yesterday and haven't got around double checking the OEM part #s yet. Plan to purchase in a few weeks and so have some time.
Edit - for plugs, realOEM has 12122158253 as the ongoing (ie not discontinued) part # for but doesn't mention the manufacturer.
Trinity - thanks for the affirmation and the iridium reco. May I know why NGK iridium and not Bosch?
Need to check your store too.
My Ride: F10 M5
Model Year: 2013
My Ride: Alpine White 2010 535 M-Sport
Just had service and they replaced the plugs. My papers state the plugs were:
"12-12-0-037-244 SPARK PLUG, HIGH POWER: 121031"
I also had to go back because one of the plugs was bad and had a short.
Based on what my trusted mechanic friend (who also works @ a BMW dealership) did, it looks you do need to hook up the car and run the tests to determine which one is having an issue. It took about 30 minutes and he showed me the results - numbers of the coil in position 4 were far far higher than the other positions. He switched the coils between #4 and #1 and ran the tests to double-check; sure enough, now #1's results were out significantly erratic.
I am sure more experienced members can chime in on alternate methods.
Plowery and Trinity - thanks for the feedback!
