iDrive screen blacked out for a sec....
Old Aug 23, 2010 | 06:05 AM
Isaiah_Charles's Avatar
So yesterday the NYC area got a large amount of rainfall. Driving around some streets was almost like drivin through rivers. I ended up turning around from one block b/c it was flooded, however some clown in an Explorer made it very difficult to make a u-turn in the tight block. I did back into some water, not sure how deep it was. But soon after my CD started skipping, iDrive started freezing up and eventually just restarted. When I got to my destination I restarted the car. iDrive has been working fine since it restarted itself. Sorry for the long story but could the water I had to drive through wet a module?? Any answers would be appreciated.
Old Aug 23, 2010 | 04:33 PM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
Definitely need to check the spare tire well in your trunk. If your car has a Micro Power Module it may have gotten wet and will eventually burn.
Attached Thumbnails iDrive screen blacked out for a sec....-micro-power-module.jpg
Old Aug 24, 2010 | 07:27 AM
Will check today, it was raining off and on again yesterday, thanks
Old Aug 24, 2010 | 07:57 AM
Howitzer's Avatar
Not only there but check your battery compartment and look where the battery is sitting. Check if there is water in there. I had that problem!
Old Aug 24, 2010 | 07:59 AM
Nope no water there I did check that.
Old Aug 26, 2010 | 07:44 AM
jerman's Avatar
So is your I-drive back to normal now? If not, what did you do? Mine just went black-out while driving! Need some advise from the Seniors here! Thanks!
Old Aug 26, 2010 | 07:46 AM
It was a little wet, but it has not acted up since that night
Old Aug 26, 2010 | 08:59 AM
Fleainat's Avatar
My Ride: 2013 550i M Sport 6MT Alpine White, 2013 X5 50i M Sport Alpine White
This happened on my last E60 except iDrive kept resetting over and over, a couple times per minute. The resolution was to replace the CCC unit (I think the nav hard drive). Hope this helps!
damian
Aug 3, 2015 04:37 AM
skeematics
Jun 8, 2015 01:17 PM
coolspot
May 24, 2015 02:26 PM
macantley
Mar 31, 2015 03:44 PM
richard
Jan 23, 2004 04:15 PM
