iDrive says to change brake fluid...
My Ride: 07' BMW 550i
I changed the brake fluid (and clutch fluid) in my 2006 530xi and used ATE SL.6:
http://www.ate.de/generator/www/com/...indow.jsp.html
I used the ATE SL.6. It is not tinted, so it is very lightly yellowish. It is not the ATE Super Blue. The idea of Super Blue is to more easily tell when you have the new fluid coming out. You can alternate flushes between the natural and Super Blue. But, SL.6 is lower viscosity and that may be slightly better. The Bentley manual says that Low Viscosity DOT 4 is preferred. You can mix low viscosity and normal. If you are in Florida, Super Blue is not street legal.
Awest91
09-17-2022 11:05 PM
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
