Idrive Menu buttons
Old Feb 9, 2009 | 06:37 PM
solrac6262's Avatar
My Ride: 2012 535i M package
Hello guys,
is it posible to retrofit the Idrive menu button I have an 04 that has 2 on it one says menu the other one is the voice command, but I bought a trim from an 07 and now my Idrive menu button doesnt fit in the hole now its bigger.
Old Feb 9, 2009 | 08:41 PM
solrac6262's Avatar
ok guys here is what I have now.maybe someone can give me some thoughts on this onee
and I think this one is a little bit bigger but don't now if the conections are the same plug and play maybe buying the switch that only has the menu on it will work, also its a little bit bigger any help come on..
Old Feb 10, 2009 | 02:59 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Attachment 71411
Attachment 71412
Hi solrac6262
Both botten are of the same size ( thats for a fact ) , are you sure that you have fitted the botten right in the trim hole ? , the hole in a 04 and a 07 trim is also of the same size , have you checked out that is not the wirring from the botten ( underneath ) that courses the problem , got stock between the trim and the botten.
Best Regards
BenAnd
Old Feb 10, 2009 | 04:43 AM
solrac6262's Avatar
Originally Posted by BenAnd' post='789264' date='Feb 10 2009, 06:59 AM
Hi solrac6262
Best Regards
BenAnd
thanks for the reply, on my old trim, the switch fits perfect on the new one is small, I believed I have seen in others and the switch has like a little piece that you can barely see alround maybe thats why it fits in the hole perfect, maybe the switch has another plastic attached to it, I will check today with the dealer and see what the difference on the switchs is..
here is a pic showing the trim
Wonky
Apr 12, 2016 08:15 PM
bimmerspeed
Sep 17, 2015 07:11 AM
Tsubasaftl
Sep 12, 2015 01:34 AM
AndreasE60
E39 Discussion
Sep 10, 2015 08:45 AM
Alan111
Sep 9, 2015 07:42 AM
