iDrive knob not working after CCC replacement
My Ride: 528i 2009 (E60)
My old CCC was failing, so I had to replace it with a used one. I programmed all of the following modules in order:
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
With SG_CODIEREN and everything is successful, however, when I go to use my iDrive controller, it does not work. Steering wheel controls work, CCC faceplate buttons work (ex. Radio presets), but the iDrive controller does not. Is there a step I missed?
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
My Ride: E60 550i
Model Year: 2010
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
- CGATE
- CHOST
- CAUD
- CTUNE
- CAPPL
sounds silly but I had this issue for weeks after I did my CIC retrofit. ended up being I didnt plug the controller in enough. id go back and recheck connections. also as previously stated check the zbe
The Solution: I updated the CGATE module with WinKFP to the latest version, and once I did that, my knob worked perfectly!
My Ride: E60 550i
Model Year: 2010
I ended up figuring it out on my own after a few days once something caught my eyes. I noticed that my iDrive knob was an LCI knob, and the date on the sticker on my replacement CCC unit was dated 2007 (pre-lci). I put two and two together and figured that there was a good chance the CCC just wasn't programmed/updated to understand the signals from the LCI iDrive controller, so likely I needed to update one or more modules (likely body gateway module)
My Ride: E60 550i sport
Probation Members
My Ride: 2008 BMW 535xi
My first comment on here
BallyM5
11-29-2011 08:22 AM
