I refuse theory about heavier car with RFTs
Old 03-07-2007, 10:35 PM
nicke60gre's Avatar
Originally Posted by EBMCS03' post='400036' date='Mar 8 2007, 07:46 AM
Hahahha its not only 13kg that you saved... its ROLLING weight that you saved... which is A LOT!
Ok, but, rolling weight is higher with RFTs, at any case
Old 03-07-2007, 10:59 PM
nicke60gre's Avatar
Originally Posted by KAF' post='400065' date='Mar 8 2007, 09:12 AM
Quite, the issue is the amount of UNSPRUNG weight, not the weight of the car.
You did not need to do all this work, the weights of specific tyres can often be found on the manufacturers websites.
Agree,
The unsprung weight is a little higher, whereas the car's weight is significantly lower.
It's not a scientific research, I was expected to see that RFTs are like 5 Kg. or more heavier in that size, but, I surprisly found that difference is only 1 Kg compaired to normal tyres. It was very easy for me, to take some pics during the swap and place them into the forum, as, I (most of the times) use to do.
Old 03-07-2007, 11:59 PM
xBMWx's Avatar
Originally Posted by nicke60gre' post='400071' date='Mar 8 2007, 08:59 AM
Agree,
I agree - I would have also expected to see a more significant difference in weight. Thanks for the info / write up.
I'm not really buying this whole weight saving thing though, especially when looking at all the options you have on your car!! The ride height and general benefits of RFTs I can understand. The ride quality is still a massive turn-off for me and I'll be interested to hear how you get on with yours because you have a non-factory delivered suspension set-up. Hope it's not too uncomfortable for you...
Cheers
Old 03-10-2007, 09:16 AM
AlexFW's Avatar
Model Year: 2005
Originally Posted by baadaaboo' post='399961' date='Mar 8 2007, 03:51 AM
you don't need to go to work today? you really have time to do all these?! amazing!!
He is a LOLman, because everyone knows that RFT are heavier .
At least +4 kg/each tire .
With spare tire you save 13 Kg, it's true : with RFT you can remove the spare tire, with normal tires you cannot remove it and you balance the maior RFT weight .
Conclusion : with a 520i can mount RFT, with a 535d/545i/550i no because of quality of tire .
Old 03-10-2007, 09:42 AM
nicke60gre's Avatar
Faulty scale :thumbsdown:
http://forum.e46fanatics.com/showpost.php?...p;postcount=813
I'm gonna burn them
340 Rwhp
No comment
Old 03-10-2007, 10:24 AM
andy545's Avatar
Model Year: 2005
Engine: 545i
Thanks Nick for the hands on info, very practical.
My experience with my 123's 18" Dunlop RFT : 26.5kg per corner.
I just received my OEM 172M's with Dunlop Sportmaxx, non RFT.
Interesting results :
Front : 26.6 kg
Rear: 28 kg
yep, the 172M's NON RFT (at least the rear wheels) are HEAVIER than the 18" RFT's ! so much for reduced unsprung weight. (in addition to the jack going back in the boot.. )
Anyways, my objective is to go to 19" and love the look of the 172's.
> If you want a rim performance (in the technical sense) upgrade > go with BBS or 167's !! they are pretty light (or other confirmed lightweight rims) . Each corner with tires should be in the region of 22kg.
If your considering going from stock 18" to the 172M's = don't expect any improvement with regards to unsprung weight.
Looking foward to the less jolting ride though...and the looks !
PS. I hope my bathroom scale meets the approval of some "members" here...it was made in 2001.
Old 03-10-2007, 10:38 AM
nicke60gre's Avatar
The one and only that my scale sums-up lighter ...is me ...because it stops at 100 Kg.
I tried yesterday the right front wheel. Looks AWESOME, no gap at all, MONSTER just a little rubbing in the inner plastic cover, ...simple mod for me, but there is no need for cutting/rolling.
Old 03-10-2007, 10:44 AM
nicke60gre's Avatar
My 167 with the "standard" Vredestein
Old 03-10-2007, 10:46 AM
andy545's Avatar
Model Year: 2005
Engine: 545i
WOW ! 8kg lighter to my my 172M's :'(
Old 03-10-2007, 10:51 AM
nicke60gre's Avatar
No, it is the front, therefore 6,5 kg lighter per front corner, 7-7.5 Kg. per rear corner
Quick Reply: I refuse theory about heavier car with RFTs
