I drive display failure?
My Ride: 07 525i
So ever since we bought this car the i drive display has acted up so i have done a little testing and haven’t really found much the screen will only come on when you first start the car for about 10 seconds the rest of the i drive system stays on and continues functioning as i would expect but the screen stays black when driving now i have run the battery dead trying to find the problem with this thing if the battery voltage drops below 11.9 volts the display will stay on (like when you start it and the voltage drops for a second) but once the voltage come back to 12.0 or higher the display shuts right back off im thinking its a display problem but wanted to see if anybody had a second opinion on things to test or try
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
If the system is working and you screen is going out just buy a second hand one and replace it. They are fairly cheap on eBay or the junk yard.
That honestly does not make sense, could just be coincidental.
Read the BMW codes, guesswork is not a good method to troubleshoot issues.
