I dont know which wall to bang my head on
My Ride: its bmw E60 2010 with winter package
So, two months back, I'm cruising with a buddy, and bam, traction control and DSC lights decide it's party time on my dashboard. Quick pit stop, restart – no luck. Park the car for a couple of days, battery's flat as a pancake. No OBD scanner, so I let it chill till I get one.
Ordered a new battery and scanner, tried jumping the dead one – no go. Slapped in the new battery, scanned the car – front left wheel speed sensor is the culprit. Changed it, but surprise, the ABS and DSC lights are still having a blast.
Now here's the kicker: no lights on startup, hit the road, and DSC light joins the fun. Brake time, ABS light wants in on the action. Plus, after swapping the battery, the generator's throwing a 15.4 nominal voltage, no dashboard errors. It's like my car's got a whole light show after I hit the gas. Need some laid-back advice to crack this automotive mystery.
(BMW E60 528i xdrive 2010)
M23E60 (01-09-2024)
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
If your alternator is at 15.4v then you need a new voltage regulator. Did you register and or code your new battery if not that needs to be done. Did you use OE or OEM sensor or an aftermarket. It being a sensor I would use OEM at minimum because aftermarket doesn't work all the time depending on the brand
M23E60 (01-09-2024)
how is the cost if voltage regulator is it easy to install?. yes i coded and the registered the new battery. its after market i ordered one from amazon for 25$ that one went bad instantly then i ordered another from my local part store for 92$ this one works but its giving these errors.
Start here, Is My Battery Bad? - 5Series.net - Forums.
do I have to do any coding after installing the regulator?
tonkaforce
08-16-2013 04:46 PM
