I discovered an oil leak!!
Old 02-25-2013 | 08:55 PM
Shlooky's Avatar
My Ride: 545i
Default I discovered an oil leak!!
so I never noticed this before, perhaps because I park my car in a garage and never cared to check, but a couple of days ago after returning to my parking spot I saw a puddle of oil. I stopped, checked it out and it was oil. Damn!!
I will have to rake it in, hopefully it's not a big thing, sigh...
Old 02-25-2013 | 08:59 PM
roskinc's Avatar
My Ride: coilvers retrofits
Model Year: 2001 and 2011
check the oil drain plug first...sometimes it gets loose if it wasn't installed at the right torque.
Shlooky's Avatar
My Ride: 545i
Will do, thanks.
Old 02-25-2013 | 09:03 PM
kengo's Avatar
My Ride: E61 and E90
First post on this forum.
I had a similar oil leak on my wife's E61. Took it to my local dealer and they told me the oil was leaking from the oil filter housing. Seems like a common problem for this model. Ended paying ¥40,000($450) for parts and labor.
Kengo
Old 02-25-2013 | 09:07 PM
e60oholic's Avatar
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust 2005 X5 3.0 (the nightmare) 1998 528i SOLD @ 173K
First of many oil leaks! My favorite one was the alternator mounting bracket seal. It was awesome, gasket cracked and dumped 5 qts of oil out the bottom! Be careful of that!
Old 02-25-2013 | 09:19 PM
Shlooky's Avatar
My Ride: 545i
Wow, i will take it in and have it checked. again I hope it something as simple as the oil drain plug, or the oil filter housing.
One of many leaks? hmmm i hope not! My 545i's got 175,000 km on her and she's been running beautifully.
Crossing my fingers, will keep you guys posted.
Old 02-26-2013 | 06:20 AM
paran's Avatar
My Ride: 2005 545i Sport
175,000 km's; and never had to change engine gaskets/seals on a 545i?
I think you're in for the $2000 surprise; I'm sad to report.
Old 02-26-2013 | 06:30 AM
MitchBMW's Avatar
My Ride: 05 545 BLK/BLK
Model Year: 2005
Sorry to say.. yes, first of many leaks. I do hope it's something simple. But eventually, it's coming! I recently discovered oil leaks, and was told the Valve Cover Gaskets were leaking the most. Had that fixed at $1600, and later was told the other leaks weren't as bad.. but would cost $5K to fully correct them. And this was from my indy shop. Right now, it's not worth me spending $5k on minor oil leaks. Plus, I don't have it to spend. Good luck
pcy's Avatar
pcy
If you just keep the hood closed all the time, no leaks... until you see a puddle on the ground. :-)
Old 02-26-2013 | 07:03 AM
DavidF's Avatar
My Ride: 545i sport
Sadly, with BMW's oil leaks are not if, but when. Usually the culprits are rubber seals, gaskets, and plastic covers (ie. valve covers). I sure wish BMW would improve their seal technology (eg. viton)
