i contaced bmw uk about the swirl flap problem
Old Jan 13, 2010 | 08:30 AM
akhtar's Avatar
My Ride: bmw 530d bmw x5 3.0d bmw 320i opel corsa opc bmw 135i dct
what is this swirl flap problem & how does it start causing damage ??
Old Jan 13, 2010 | 10:35 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
It concerns most diesel engines and may cause a massive engine malfunction.
If you have a diesel E60 you really should read about it.
Here:
https://5series.net/forums/index.php?showto...mp;#entry489714
https://5series.net/forums/index.php?showto...8&hl=engine
https://5series.net/forums/index.php?showto...ning+the+intake
https://5series.net/forums/index.php?showtopic=70452
Old Jan 13, 2010 | 10:41 AM
Anzafin's Avatar
Originally Posted by craven79' post='1089221' date='Jan 12 2010, 11:41 PM
i have tried searching but can't seem to find out if this swirl flap issue affects 2.0d models. I have a 55 plate 520d, all the posts seem to be about 525d and 530d's. Thanks in advance.
If you have the swirl flaps, then it affects. You can check if you have the swirl flaps by yourself.
1) Open the bonnet
2) with a little mirror and a torch, try to find the long shiny rod that moves the flaps on the right side (when facing the car on front of it) of the engine. It locates under the intake manifold so it might be a bit difficult to see, but if you can find the rod, then you have the swirl flaps.
Here you can see the shiny rod you have to search for:
And here you can see where it locates. Under that plastic intake manifold of course:
I hope this helps.
- Antti -
Old Jan 14, 2010 | 11:20 AM
craven79's Avatar
My Ride: '55' 520d m sport
Thanks Anzafin i will have a look for that. I have read your post about removal of the swirl flaps and was wondering if you knew if the proceedure was basically the same for my 4 cylinder 2.0d thanks again.
Old Jan 14, 2010 | 11:30 AM
Anzafin's Avatar
Yes it is basically the same .
Old Jan 18, 2010 | 12:22 PM
530dE60's Avatar
Got mine removed today. Now I can sleep more easily ! I was told mine were the modified swirl flaps so I wonder if failure was less likely. Also had the oil/air separator changed at the same time. Now I can forget about the swirl flap issue. Didn't notice any change in the car after the swirl flaps were removed. I guess worth doing just for the peace of mind.
Old Jan 18, 2010 | 12:31 PM
Anzafin's Avatar
Good to ho hear! Congrats!
Old Jan 23, 2010 | 08:43 AM
craven79's Avatar
i've just taken out the swirl flaps and put blanking plates in and tried to clean the egr and inlet manifold as best i can with carb cleaner, put everything back together and the engine management light is on and idrive is saying increased emissions. Do you have any idea what i might have done wrong. thanks
Old Jan 23, 2010 | 08:50 AM
Anzafin's Avatar
Did you disconnect the battery for the operation?
Check also the electric plug on the EGR valve that it is pushed in correctly. Also check all other plugs and tubes too.
TroyE60
May 30, 2019 05:01 PM
JonathonK
Mar 27, 2015 08:13 AM
Eborlindum
Mar 23, 2015 02:15 AM
6foot4
Mar 17, 2015 02:49 PM
BEZ101
Mar 10, 2015 06:22 AM
