Hydraulic lifter??
Old Dec 4, 2013 | 12:23 PM
e60rider's Avatar
My Ride: 2008 528xi (Silver)
Default Hydraulic lifter??
Its been getting cold where i live, and i am noticing a very loud ticking noise from the engine bay left side, where the valve cover is (left side if you were looking into the engine bay from the front). The ticking sound does change with rpm, i am thinking it is the lifter's. My car most likely has the old cylinder head style as the production date of my car is 23.04.2007. I did not have this issue when it was really warm. i did have this sound for the last couple of weeks, but today it was randomly extremely loud on the second startup of the day. (went to work, and sound was there but not very loud, coming back from work the ticking was easily heard in the cabin)
I am wonder if any one got this issue replaced and for how much?
Is it harmful for the engine to be running like this? (will it harm the car, if i dont get it fixed)
Old Dec 4, 2013 | 12:24 PM
e60rider's Avatar
By the way i am out of luck and have no warranty!
Old Dec 4, 2013 | 06:56 PM
ncsugrad2006's Avatar
Can you post a video of it?
I assume you have checked to make sure you have enough oil in the car?
Usually a loud TICK TICK TICK noise is either lifters or rod bearings
TAP TAP TAP is more like rod bearings
Old Dec 5, 2013 | 09:15 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
N52? If so it's probably the common "N52 tick"
what oil are you using?
Old Dec 5, 2013 | 05:58 PM
e60rider's Avatar
ill post a video soon, but yes it is N52. and i am not sure 100% but i got the oil change done at the dealer in Michigan and i suspect 5w-30?
Old Dec 5, 2013 | 06:34 PM
Yeah, those engines are pretty notorious for ticking.. I believe the lifters are the common cause
Mihainede85
Sep 5, 2024 12:24 PM
Stuboski
Nov 5, 2021 06:58 AM
Bounce
Aug 31, 2015 10:04 AM
PelicanParts.com
Aug 28, 2015 12:12 PM
SDALEX
Aug 17, 2015 04:10 PM
