HUD navigation?
My Ride: BMW e60 525IA 12/2003
Hi Esser
Reason why your HUD navigation don't work , is that when you got that tracking device mountede , they have got the MOST-Bus ( optical cable ) dismanteled some how , proberly somewhere under the dashboard by the cluster.
Get that fixed , and you will get your "arow's" back in the HUD :-)
Regards
BenAnd/Denmark
Regards
BenAnd/Denmark
Engine: N54
Hi Esser
Regards
BenAnd/Denmark
Regards
BenAnd/Denmark
Hi
Correct , if the MOST Bus is disconnected by accident nothing will work on the Bus , but a week signal into the HUD ( connector not fitted right ) some time make the HUD not "see" the signal , but the loop still works ( seen that often )
The HUD get's some of the information throug the K_Can_Bus HIGH & LOW ( actual speed , speedpilot settings , turn signal ,alarm ínfo's, outside temp. etc. ) , but all navigation informations comes throug the MOST-Bus from the M-ASK or CCC
bestofthebest
01-05-2016 07:47 PM
