HUD heads up display Problem
My '05 545 has HUD. The HUD, from time to time, goes almost invisible. If you look closely, you can still see the speedometer display, but it's barely visible. No rhyme or reason to when it occurs. Sometimes it will remedy itself after the engine has been turned off.
Any ideas? Anyone else experience the same problem?
My Ride: 2005 545i with Sport Pkg, Nav, HUD, Cold Weather Pkg, Rear Shades
I have the same model year car, and have not had any problems. I would suggest you go to the dealer and have them check it out.
Where are you located? Please update your signature with your ride details and location information in your profile.
Has happened to be some. I believe it is only under very bright sunlight conditions. I think I remember a brightness setting for the HUD. If so, I'm certain I have mine set on brightest. It has never been a distraction.
Model Year: 2005
Engine: 545i
when this happens? or maybe clean the light sensor for the HUD...
My Ride: 2007 550i White/Black, SMG, Sports Pkg, Comfort Access, Nav, HUD, Satellite Radio, Anthracite Maple Trim
2006 X5 3.0, Black/Black, Sports Pkg, Premium Pkg, Xenon Adaptive Headlight, NAV, Rear Climate Pkg, Anthracite Trim
My works fine too..
My Ride: 2007 Titanium Gray 550i, with sport, nav, HUD, Logic7, sat radio, cold weather, rear side airbags, rear seat heaters, and it goes like a bat outta hell!
Mine works great....there was one time during the middle of the day when the HUD did start to fade and get fuzzy.....then I realized the sun was shining directly at the HUD port in the dash......as soon as my direction changed a bit, all better.
socale39
09-05-2023 08:30 AM
