How to Rest Engine Oil Warning and other Warnings
Old Sep 28, 2010 | 02:15 PM
jvilla's Avatar
I've actually viewed videos on how to reset this but it didn't work, maybe was for another model but I tried to look specifically for my model (e60 07 BMW 550i). The oil was changed but apparently the mechanic shop didn't (or know how to) reset the Engine Oil indicator. Does anybody know how to do this?
Also, you can see from the image below, the Microfilter and Brake Fluid icons are on. Is this anything that I can fix/replace myself. Trying to save money and also learn more about my car to be a better informed owner. Does the MicroFilter need to be changed, is it important?
Thanks
Attached Thumbnails How to Rest Engine Oil Warning and other Warnings-img_0845.jpg
Old Sep 28, 2010 | 02:30 PM
SilberGrauE60's Avatar
microfilters are simple to DIY. There are two of them under the hood behind the firewall underneath some rectangular covers. They filter the air that enters the cabin via the climate control. Probably should inspect first to see if really dirty. I ordered mine online from Amazon.com (TYN brand, I think). I got the activated charcoal for added odor elimination.
as far as resetting the service indicators, I believe there is only one procedure for all e60's. Possibly you didn't have the key in the correct position. For a key, move it to second position. For a start button, click it twice(?) without pushing the brake pedal--I have a key, so not sure on this one. All the dash lights should light up. Then press and hold the trip reset button until the caution symbol comes up. Then push the button until the symbol you want to reset comes up. Then press and hold until Reset? appears. That's about it.
Old Sep 29, 2010 | 04:30 PM
dxb_8788's Avatar
SilberGrauE60 +1
Old Oct 1, 2010 | 10:38 AM
realbaishui's Avatar
Just copy and past from other places.
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost"
Old Oct 13, 2010 | 11:28 PM
ey2001's Avatar
My Ride: 525i
i reset my oil light and other lights before but this was my first time doing the brake light.... i did the usual but it reseted from 900 to -15000. anyone know what i should do?
gergnang
Feb 2, 2021 07:29 AM
demosthenesish
May 1, 2015 06:02 AM
Steven06
Apr 8, 2015 12:32 PM
Stranger12
Apr 5, 2015 10:42 AM
dv8ed
Dec 24, 2003 07:41 PM
