How to Reduce the throw of the clutch pedal?
My Ride: I GOT A 2007 TITANIUM GRAY/AUBURN LEATHER 545I 6SPD MANUAL. COLD WEATHER PACKAE, PREMIUM, PREMIUM SOUND LOGIC 7, SPORT.
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
On the older E39 models it was not a problem. Offcourse the clutch throw was not as long on the E39 and the grabing occured at the bottom.
It is totaly different with an E60. I feel like i am driving an 18 wheeler, and if anyone knows what to do to reduce the clutch throw, please help !!!
[snapback]69946[/snapback]
He has removed the dead area at the end of the clutch throw by glueing wood. Removing your CDV will give you the linear clutch travel and engagement you are looking for. Also search for CDV (Clutch Delay Valve)
I have already removed the CDV Valve, but the travel is now even longer. the clutch certainly feels more agressive and better, but the travel is way to long...
[snapback]69979[/snapback]
Replacement of the CDV valve is an absolute must. All it is is a pinhole restrictor in-line with the clutch hydraulic fluid. It causes a delay between the time you move the clutch pedal and the time the clutch activates. I have yet to hear of one person that thinks it is a good idea. Dave Zeckhausen simply bores out the existing CDV and sells them for about $35. I recommend him because the valves are cleaned thoroughly to insure there are no metal particles left that could damage the system. You will notice that your clutch responds immediately to your foot, and it becomes much easier to shift.
My Ride: On Order:
2006 525i
Alpine White
Auburn Interior
Premium Pkg
Sport Pkg
Cold Weather Pkg
Xenons
Sunshades
Sat Radio
Navigation
wolverine, can you provide pictures of your clutch pedal stop. Very good idea by the way....as long as it's clean.
Thanks!
Thanks!
Originally Posted by Jimbo' date='Dec 18 2004, 02:05 AM
Do you have to put the clutchi in to start the car?
[snapback]70198[/snapback]
Wolverine,
Who did your CDV replacement in Cincinnati or did you do it yourself???
[snapback]69995[/snapback]
[/quote]Wolverine,
My Ride: BMW M-Power
A) I would not modify the position of clutch travel/position in your car by ways of these mickey mouse stoppers. You are gonna pay for it when you are hit w/ clutch replacement bill of $3500 that BMW NA refuses to pay due to "owner's abuse"
Fix the problem (if there is one) and not jerryrigg a solution.
I disagree that the E39 clutch has a shorter travel than the ones one E60. I have a E39 stick and I did NOT notice any material difference between the travel of the 2 clutch.
C) I can't see how a replacement of a drilled out CDV can cause a longer travel. If you know the process, it is physically impossible. i would check if something else was foul-up during the CDV swapt process.
Good luck fellas,
beewang
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
Good luck fellas,
beewang
wooboodoo
10-25-2015 02:58 PM
PelicanParts.com
09-10-2015 10:02 AM
