How long does diesel last for?
I've got a 5 litre emergency jerry can of diesel in the boot. I'm just wondering how long it will last for? I intend to pour it into the car's tank and fill it up with fresh fuel every now and again but just trying to work out how often I should do this.
TIA
TIA
My Ride: 2005 530d auto ,Carbon black,all options but HUD and sunroof
You have to make sure that the can is full most of the times specially in cold (freezing ) conditions. Not much happens to diesel unlike petrol.
My Ride: 540i
Model Year: 2017
Originally Posted by ali-cap' post='996106' date='Sep 2 2009, 01:35 PM
You have to make sure that the can is full most of the times specially in cold (freezing ) conditions. Not much happens to diesel unlike petrol. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Diesel will store in your dry trunk for a good while. The problem occurs in partially filled outside, or underground tanks, where moisture will condense.
Hint: As temperatures drop replace the diesel in your jerry can to take advantage of anti-gelling agents or winter blends that fuel suppliers provide.
My Ride: 2006 BMW 550i
the question is, why do you keep emergency fuel with you? do you run out of fuel alot?
plus, running a diesel on empty, sometimes means bleeding the fuel system, so that it starts.
bestofthebest
01-05-2016 07:47 PM
