I oen a BMW OEM 2007 M5 replicia by extrrior apperance but it is not the real m5 and I am ready to get right with the BMW cominity and Ok guys I am getting teady to "Debadge" my m5 badge off my rear deck lid and just leave it blank or use the "M" part and what are your thoughts, and just wonder which.is the cleanest and easiest way to do this. And cost the less money? I am thinink just to leave it blank and make prople wonder what it is? But what ate your thoughts.
Thanks in advance forum. Eddie aka Presley348 |
I used a fishing string, run it in between the badget and the body, used goo gone, clean it out.
fishing wire. then picked off as much of the reside that i could. then use meguiars scratch remover to get the rest off.
I've found that Goo Gone is pretty harsh. I would try to clean it off as much as possible by using a blow dryer to warm up the residue first before using Goo Gone.
Use a blow dryer on the decal for 10-15 seconds until it gets warm to loosen the adhesive material. Use floss to with two hands and gently press behind the decal into the adhesive and zig zag it until it cuts through the adhesive. Use goo gone or soap and water to remove any excess adhesive left over.
I used dental floss and windex to wipe off the glue. Goo Gone may be slightly strong IMO
fishing line, bumper sticker adhesive remover, and some carnuba wax
Done |
