How do I find out what this means?
My Ride: 05' 545i
Titanium Sliver, Black Dakota leather
Sport Package, NAV, Premium Sound Package, AUX. input.
Just got my car back from the dealer.
On the invoice its says:
PERFRORM SIB# 12-11-05 LBL CODE 442 N62 PROGRAM O
They told me it was a recall and I would be updated to ver. 20 of the software.
The last time I got a software upgrade I lost everything - phone, address book, etc.
This time everything was still there.???
Can anybody help shed some light on this for me?
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Here u go:
SI B12 11 05
Engine Electrical Systems January 2006
Technical Service
This Service Information bulletin supersedes S.I. B12 11 05 dated August 2005.
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
designates changes to this revision
SUBJECT
Service Action: N62 Reprogramming for Incorrect Oil Service Interval
MODEL
E60, E63, E64 with N62 produced from 09/01/04 up to 03/10/05
SITUATION
Due to DME software error, an incorrect CBS oil service indication may be displayed.
Two scenarios are possible:
Oil Service notification is displayed prematurely, with quite low vehicle mileage, or
Oil Service notification is not displayed at all, with the actual vehicle mileage exceeding normal oil change interval.
AFFECTED VEHICLES
This Service Action involves 545i, 645Ci and 645Cic vehicles, with N62 engines, which were produced from 09/01/2004 up to 03/10/2005.
In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of the DCS (Dealer Communication System). Based on the response of the system, either proceed with the corrective action or take no further action.
The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.
Model
545i
B088625 ? B089381
545iA
CN63006 ? CN65796
645Ci
B215675 ? B216118
645CiA
B191188 ? B193496
645Cic
B260715 ? B261101
645CicA
B322923 ? B326261
CORRECTION
On the affected vehicles, reprogram/recode control modules with SSS loaded with CIP 17.1 or higher. After programming, using DIS/GT1, perform CBS data correction/reset as described in the procedure below.
PROCEDURE
Reprogram and recode the affected vehicles using Software Service Station loaded with CIP 17.1, or higher. For programming/coding instructions refer to SIB 09 05 01 Coding / Individualization / Programming), Procedure "B".
After programming/coding is completed, perform CBS data reset/correction using DIS/GT1 loaded with DIS CD 41, or higher with online update "UPD-DIS: CBS correction error_ME9.2.2" (this update is also valid for DIS CD 42.0).
After automatic determination, select: Function Selection, Service Functions, Maintenance, and then Test plans.
From the list of test plans, first select and execute: "CBS engine oil functionality error S1214_RESBODME", to delete adaptation values.
Then, select test plan "CBS Reset ? SCBS 6003", following by [1] "Engine oil" to clear incorrect CBS data.
Finally, select test plan "CBS correction of vehicle date ? SCBS 6004", following by [1] "Engine oil". Calculate the correction factor (in %) using the attached "B121105 CBS correction" table (with example included). Enter the correction factor into the test module.
NOTE:
If the nominal oil change interval (15,000 miles) has been exceeded without service notification, an oil service has to be performed immediately. In such a case, do not perform CBS correction (test plan "SCBS 6004"). After the oil service, reset the CBS data only (test plan "SCBS 6003").
LABEL INSTRUCTIONS
This Service Action has been assigned code number 442. After the vehicle has been checked, and corrected if necessary, obtain a label (SD 92-278) and:
emboss your BMW dealer warranty number in the middle of the label (1);
punch out code number 442 printed on the label (2) and,
affix the label to the B pillar as shown.
If the vehicle already has a label from a previous Service Action/Recall Campaign, affix the new label next to the old one. Do not affix one label on top of another one because a number from an underlying label could appear in the punched-out hole of the new label.
WARRANTY INFORMATION
Reimbursement for this Service Action will be via Campaign Entry.
Defect Code
00 12 04 02 00
Work Package #1:
Generate measure plan, no programming update is needed.
Correct CBS data
Labor Operation:
00 55 885
Labor Allowance:
8 FRU ? E60
7 FRU ? E63, E64
Work Package #2:
Program control modules (without CAS).
Correct CBS data.
Labor Operation:
00 55 886
Labor Allowance:
12 FRU
Work Package #3:
Program control modules (with CAS).
Correct CBS data.
Labor Operation: 00 55 887
Labor Allowance: 13 FRU
SI B12 11 05
Technical Service
SUBJECT
MODEL
SITUATION
AFFECTED VEHICLES
Model
545i
B088625 ? B089381
545iA
CN63006 ? CN65796
645Ci
B215675 ? B216118
645CiA
B191188 ? B193496
645Cic
B260715 ? B261101
645CicA
B322923 ? B326261
CORRECTION
PROCEDURE
NOTE:
LABEL INSTRUCTIONS
Defect Code
00 12 04 02 00
Work Package #1:
Correct CBS data
Labor Operation:
00 55 885
Labor Allowance:
8 FRU ? E60
7 FRU ? E63, E64
Work Package #2:
Correct CBS data.
Labor Operation:
00 55 886
Labor Allowance:
12 FRU
Work Package #3:
Correct CBS data.
canadae60
06-18-2015 02:48 PM
