How to check Engine Temp for E60 (535i 2010)
Hi guys,
The 2 important function that should have a display gauge is the engine temp and the oil level but there is no gauge on my car to show the engine temp at all and there is no dipstick to check my level oil. In the iDrive only show the oil level is ok. it does not tell you exactly what it like others have dipstick. Is there any place else showing the engine temp? I'm little concern about this cuz I live in a dam hot state in the summer time. |
Get a JB4. Not only will it safely transform your car's performance, it includes a ton of extra nice-to-have features as well. For instance, you can easily hijack the stupid economy gauge in the instrument cluster and turn it into one of several useful gauges, including a water temp gauge. And the best part is it can all be changed on the fly using the volume and channel buttons on the steering wheel.
u check it in the cluster.. its a pain in the butt .. check this out
Originally Posted by DanL
(Post 1495737)
Get a JB4. Not only will it safely transform your car's performance, it includes a ton of extra nice-to-have features a well. For instance, you can easily hijack the stupid economy gauge in the instrument cluster and turn it into one of several useful gauges, including a water temp gauge. And the best part is it can all be changed on the fly using the volume and channel buttons on the steering wheel.
(Post 1495737)
Monitoring a coolant temperature gauge in a 535i is not very useful unless you are very familiar with the various temp maps the system is managing. Normal is between 194 to 226 deg. The engine runs hottest under low loads to get the highest mileage because of lower friction and runs cooler under high loads to improve cylinder filling and increase torque. The different modes are
226 deg. = economy 219 deg. = normal 203 deg. = high mode 194 deg. = high mode in conjunction with map thermostat Most drivers would not read or understand the temp gauge in a meaningful way. Regarding the dipstick, I got over it a long time ago. |
Originally Posted by vk535i
(Post 1495777)
is JB$ work on E60 engine? where do I purchase it ?
JB4 PNP (N54 Stage 3) BMW Performance Tuner - Add 100+ HP - BurgerTuning.com |
Originally Posted by baveagle
(Post 1495779)
going back to post #3 in this thread - has anyone with an early build ('04, '05) car had any luck with this? I could get my cluster to accept the code and allow me to scroll to all of the various sub-menus, but I couldn't get it to actually display engine temp for me.
Originally Posted by KyleB
(Post 1495870)
