how to adjust vent air temp. on E60?
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
It is a pain. AC is usually vented chest high and heat is vented to the floor, I guess it's personal preference.
My Ride: 07' 550i sport; Sapphire Black/Auburn; sport package; steptronic; navigation with R.T.T.I.; heads up; cold weather package; Logic-7; BMW MOST ipod kit; Motorola V3 snap-in adapter; rear heated seats and rear shades; anthracite headliner; sirrius sat. radio; M-aero kit; OEM style 166 Wheels with 245/35-19 front and 285/30-19 rear Michelin PS2s.
Originally Posted by blinkme_210' post='345869' date='Oct 17 2006, 12:05 PM
So what's the point of even having the regular temperature dials on the front of the climate unit then?
Currently my temperature setting in iDrive is set to white(medium?), and that seems to work pretty well. If it gets a little cold, I just turn on the seat heaters to high.
I'll have to become proficient with the i-drive when I get my car.
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
I think I need to read the manual, but guys help me clarify our AC system...
I always don't know why there's this manual adjustment on top of the temperature control of the AC, to me it seems redundant, but I guess there's an actual use of it...
1. The manual adjustment in idrive (not the knob on the dash that dials in the temperature) only affects the center two vents? The side vents should not be affected regardless of the manual settings?
2. My wife always complain our cars (E60 and x5) hardly gets warm air unless we put the temp settings to like 80F, and that doesn't even get that warm. Is that normal?
3. Is there independent manual adjustment for both the driver and the passenger? I thought there's only 1 manual dial on my x5... If that's the case, we can't have separate center vent air? My wife always want a warmer settings than I do.
4. Is the rear vents independent on the manual idrive settings up front?
Yes, i should check the manual...
2. I think the "problem" is that, once the car inside has warmed up, the air from the climate system will be roughly at the target temperature (say 70). Human skin perceives as "warm" temperatures from ~80 up. If you have ever dived into a pool at 68 or 70, you will know it feels uncomfortably cold, however it's the most comfortable air temperature for a clothed person. So, unsurprisingly, if you don't set the temperature to 80+ the air coming out will be felt as "not warm". (This of course is only valid once the car inside has warmed up. While warming, the air will be coming out "hot")
3. There is independent setting of the overall temperature (within reason - you can't really have one person at 60 and the other at 80), but not of the face vents.
4. Yes - again within reason. And it only controls the face vents; the footwell vents are controlled by the temp setting at the front.
Hope this helps.
