Hook Ring Seal Update
My Ride: 2007 530Xi
Does anyone know if BMW ever updated the part for the N52 hook ring seals so they don't destroy the head? Thinking of replacing my cylinder head on my '07 530 with either a head from the dealer (2$k) or buying one online (1.5$k). Have the vanos issue but after the solonoid replacement, still have P0012 intake timing fault...thinkning its the bearing ledge. Just trying to do some research on the issue before spending $$.
My Ride: e90
I had that issue few years back, it ended up being the oil pan gasket clogging up the oil pick up line which messes with the vans. I also cleaned up the vanos filter on the side.
Here is a copy of the bearing ledge SIB I found some time ago and kept a copy of. It doesn't indicate an improved head. One of the bearing ledges is replaceable and one is cast into the head.
SI B11 02 08
Engine October 2010
Technical Service
This Service Information bulletin supersedes SI B11 02 08 dated August 2010.
designates changes to this revision
SUBJECT
Power Reduction, FC 2A82 Intake VANOS and/or FC 2A87 Exhaust VANOS Camshaft Faults are Stored in DME
MODEL
E82 and E88 (1 Series) with N51, N52K and N54 engines produced from 1/2008
E90 and E91 (3 Series) with N52 engine produced from 3/2005 through 6/2006
E90, E91, E92 and E93 (3 Series) with N51, N52K and N54 engines produced from 7/2006
E85 and E86 (Z4) with N52 engine produced from 1/2006
E83 (X3) with N52K engine produced from 9/2006
E60 and E61 (5 Series) with N52, N52K and N54 engines produced from 3/2005
E70 (X5) with N52K engine produced from 10/2006
E71 (X6) with N54 engine produced from 1/2008
SITUATION
The “Service Engine Soon” (MIL) lamp is illuminated and a power reduction is clearly perceptible. This situation can occur after driving for some time with the engine already at full operating temperature. If the ignition is cycled, the engine then usually performs normally.
The following faults are stored in the DME:
2A82 VANOS intake – stiff; jammed mechanically
2A87 VANOS exhaust – stiff; jammed mechanically
3100 Boost-pressure control, deactivation – boost-pressure buildup prohibited (N54 only)
CAUSE
The VANOS faults can be caused by an insufficient oil pressure supply to the inlet VANOS adjustment unit. To effectively move the camshafts to the target positions in the specified time and under all engine conditions, sufficient oil pressure supply to the VANOS control pistons must always be available. When the engine operation requires that the VANOS quickly advance or retard the intake or exhaust camshaft, fault 2A82 or 2A87 may be set if the camshaft is “late”, or does not reach the target position. In this situation, engine power may be reduced and a check control message is displayed. The consequential fault 3100 can also be set in the DME fault memory as well.
PROCEDURE
Perform all applicable test plans for the faults stored. A mechanical restriction or electrical failure of the VANOS solenoid and/or the electrical circuit can cause insufficient oil supply to the VANOS assemblies as well. If the results of the test plans are inconclusive then proceed to step 2.
The oil filter cap insert may have been inadvertently removed during the vehicle’s last oil service. If this insert is not installed, it will result in non-filtered engine oil being supplied to the engine, thus possibly clogging or damaging the VANOS solenoids.
Replace both VANOS solenoids and change the engine oil and filter. Drive the vehicle to verify effectiveness. If this repair is inconclusive and the fault returns, continue to step 4.
If the oil filter cap is found intact, it is possible that the camshaft hook ring seals (3) have worn a groove into the camshaft bearing ledge (1), causing a drop in oil supply to the VANOS unit.
Camshaft bearing ledge
Intake camshaft
Hook ring seals
Note the deep grooves worn into the intake camshaft bearing ledge by the camshaft hook ring seals.
Acceptable camshaft bearing ledge – minor wear marks from the rotation of the camshaft are normal.
If the oil filter cap insert is found to be missing, then the entire oil filter housing cap must be replaced (refer to the EPC). If excessive wear to the camshaft bearing ledge is found, it is only necessary to replace the camshaft hook ring seals and the affected camshaft bearing ledge.
SI B11 02 08
Engine October 2010
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
Intake camshaft
Hook ring seals
Here is another reference with some pictures:
Tech Tip: BMW?s Power Reduction and Vanos Faults Are Stored In DME
My Ride: 2007 530Xi
Now that you mention it, the oil pan gasket is leaking....is there a writeup on this somewhere? Would love it if that was the problem! Where is the vanos filter located? Hard job?
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
