Hong Kong E60 sub-Forum
Old 10-15-2006, 05:14 PM
  #3911
AC_S5's Avatar
Originally Posted by mic325' post='345108' date='Oct 16 2006, 12:27 AM
AC_S5, a DIY link for the rear license plate LED on a E90 in Hong Kong.
http://www.e90post.com/forums/showthread.php?t=33362
Wow after seeing all the wires and stuff, I got dizzy and sweaty by just looking at it. I think mine is a better solution.
I just broght a pair of resistor $10 HKD and just put it right inside the plate light housing, works the same with no error messages and half the fuss.
Old 10-15-2006, 06:54 PM
  #3912
EBMCS03's Avatar
Ya but thats not good... the resister gets too hot cant dissappate the heat. Thats why I've never done it on my car yet. Been too lazy to look for correct resisters and find a way to mount / fit them in that small area... Now I wonder if the E90 is similar to the E60 where I can do what that guy did...
Old 10-15-2006, 07:24 PM
  #3913
AC_S5's Avatar
Don't have a problem with it so far, but you know after seeing the guy on E90post with all the wires and stuff, it will be a hassel taking it out when bringing the car in for service as suggest as there are wires wraped around the trunk and stuff.
Plus I don't think I would want to invest in a soldering kit just to get some LEDs under there. Too much work if you ask me.
I like mine now, quite ok if you ask me.
Old 10-15-2006, 07:54 PM
  #3914
EBMCS03's Avatar
Hahaha But I think the E60 has a lining cover to cover up all thsoe wires... Now the question is that lining easy to pull off. I'm not too worried about service... they really cant blame it on those... if so its easy to take off.
and everyone should have a simple sodering iron.
This is basically the same thing as what you did but he just used larger resistors and found a place to mount them... have you checked to see if everything is still ok in there?
Old 10-15-2006, 08:35 PM
  #3915
pinguhk's Avatar
My Ride: Mini Cooper
You should be worried about service cos BMW will say your car has been mod and will not fix it.
Old 10-15-2006, 08:41 PM
  #3916
EBMCS03's Avatar
Ya... but in the US if they cant trace it specifically to those lights and resistors they cant blame the mod for it. Say my engine was leaking oil they cant say your resistors is causing that... or if they can I can easily remove it...
Old 10-15-2006, 08:49 PM
  #3917
AC_S5's Avatar
I have checked and everything is normal under there except the LED is not working properly. Maybe the resistor is too big. Not enough current going through it.
Old 10-15-2006, 10:03 PM
  #3918
Bunbun's Avatar
Guys, I just checked out Audi's new showroom in Admiralty and the new TT also just arrived. Man, I must say, it's a really nice car. The interior is (sad to say) much better made and finished than BMW's. The seat is so comfortable and gives plenty of support. All in all, it's a very futuristic looking sports car. The 2.0TT is selling at $460K, does 0-100 in 6.4s !
Old 10-15-2006, 10:20 PM
  #3919
Lawrence's Avatar
Get in for the second car!
Old 10-15-2006, 10:22 PM
  #3920
Lawrence's Avatar
Maybe that's the reason you said the LED is not bright enough! Try smaller resistor.
Quick Reply: Hong Kong E60 sub-Forum
