Hong Kong E60 sub-Forum
Old 10-30-2010, 03:09 AM
  #29301
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by newbie2
Bill, you misunderstand my meaning, I am reminding other buddies that the scan at AK is not free, should pay AK!
Yeah, i will stop the mods for the moment and focus on fixing the wheel issue. AK helped to change the wishbone already and the vibration reduced but still have it at high speed. I suppose he has helped to inspect the "steering rack" which capt told me.
I don know, I am sure that I want to fix it but don know how to start and where to go to start. Go AK? or go balance again? or go to do a computer alignment config....?
balance again it is the cheapest to do 1st
Old 10-30-2010, 03:10 AM
  #29302
pinguhk's Avatar
But the tyre shop said the rear wheels are not required to do balance, only the front is require.
Anyway, I will do it again.
that good hope it will fix it and then you can start modding again.
Old 10-30-2010, 04:07 AM
  #29303
Small Tomato's Avatar
My Ride: '08 530i Luxury LCI
Is the steering wheel virates when doing higher speed? Or you mean the whole car is slightly shaking?
Old 10-30-2010, 07:16 AM
  #29304
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Should be the steering wheel under high speed.
Alan, need friend giving to whom exchanged the wheel with you.
Old 10-30-2010, 07:18 PM
  #29305
newbie2's Avatar
only the steering wheel vibrates when doing higher speed. the car body did not shake, doing perfect.
Old 10-30-2010, 07:23 PM
  #29306
newbie2's Avatar
Ricky, I need you helping to test the car's steering wheel vibration. Sometimes I am not very sure this is normal after changing to 19" rim. It is quite consistent to appear when moving higher than 100km, so should be easy to reproduce. When will u be free?
Old 10-31-2010, 01:09 AM
  #29307
Did you use a spacer for upgrading to 19" wheels?
Old 10-31-2010, 04:04 AM
  #29308
pinguhk's Avatar
ricky car had this too for the rep M6 wheels.
Old 10-31-2010, 04:09 AM
  #29309
pinguhk's Avatar
I have spacers for my 19" and are fine. no shaking at any speed but the spacer are made in US not HK
if they are made in HK they there is a big chance that they are not that good. :thumbsdown:
Ask mark he knows, he had the HK made 1s
Alan if you have HK spacer I would take them off and get some better 1s like H&R like mark
Old 10-31-2010, 05:56 PM
  #29310
newbie2's Avatar
No spacer.
Quick Reply: Hong Kong E60 sub-Forum
