Hong Kong E60 sub-Forum
My Ride: Mini Cooper
wow the big computer at AK looks like alot of fun to play with.
I will spread the word out on all forum to let ppl know he as the big BMW and Mini computer
when was the last time you had it checked?
as you can see from my computer print out, my car was out of alignment 0.21degree front and
0.12degree front right "toe".
they have all your car's details with suspension set-up etc,.in the computer,
the car was raised off the ground etc,.
l hope this helps, it's bad having vibrations.
maybe you can go to Tin Hau with Captain's info
of couse
most shop with big computer charge about $600 for a scan and $400 for a error code fix.
AK should do this too and charge a $100 less so he gets more customer by just doing this kind of easy job.
after all this is easy money![Twoup](https://5series.net/forums/images/smilies/imported/twoup.gif)
2 years ago I was charge $200 for the big computer to scan my Smart42 and other $200 to fix the error code.
this was very cheap.
for your info his name is Mario and fixes smart car.
he is a free lancer no shop.
I should buy a computer and start a bizzness just scanning cars and fixing error code, so easy money.
My Ride: carbonized MB coupe
you have to pay Alan, computers are expensive, get the computer checked at AK.
for the wheels, i never saw such a ramp at the megabox joint, that and the computer is bigger than their shop!
Alan get your wheels done now or it will screw up your suspension and steering fast!!!!
or why don't you just get new wheels?
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
of couse
or why don't you just get new wheels?![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
the computer is inside which you did not go into the shop.
I think Alan wheels is fine.
best to get them rebalanced it the cheapest way to test to see if it is the wheels.
only about 300 to do all 4 wheels
Yeah, i will stop the mods for the moment and focus on fixing the wheel issue. AK helped to change the wishbone already and the vibration reduced but still have it at high speed. I suppose he has helped to inspect the "steering rack" which capt told me.
I don know, I am sure that I want to fix it but don know how to start and where to go to start. Go AK? or go balance again? or go to do a computer alignment config....?
the ramp is on the floor inside, it is same as the 1 you took of photo and then they just put claps on each wheel and it is wireless.
Anyway, I will do it again.
